Why are my wallets green?
Dave271069
Re: Why are my wallets green?
Post by Dave271069 »
why are my wallets green?
temp 190c
time 55-60 secs
image printed out good from epson sx130
paper correct side coralgraph prem quality NON-GENERIC a4 sublimation paper
any ideas?
DAVE
vB_ID:1233
vB_ID:1233
Typcal grayscale problem... Hav you got icc instaled corectly?
Also if you print in ps. Please tur picture to blac and white befor print. I know is already b&w but this will remove all casts.
Dave271069
hi paul, using a paul icc, only thing thats different is paper. i can understand why the acual print (on right) is fine, just like the original i scanned. but when subbed onto wallet its green, my mugs and other stuff are fine. maybe i will try this print on a mouse mat and see how it comes out.
i have not adjusted anything else in photoshop just printed original .
Dave
Oh... I picture is scaned then make sure you change it as b&w. As i bed you scaned b&w pic on color settings on scaner ;-)
Dave271069
Just printed a slate with the same printout as used on wallet. The slate has come out perfect, in fact 100% better. So I still don't understand how the wallet was green as the picture I used to sub it was not.
all media are different :)
try something else ie other fabric item...
also what pressure did you used for your wallet?
I found that they print best with heavy (VERY) pressure
kaskade
Post by kaskade »
Dave271069;55618 wrote:Just printed a slate with the same printout as used on wallet. The slate has come out perfect, in fact 100% better. So I still don't understand how the wallet was green as the picture I used to sub it was not.
did you get this to work, I have just had the same problem with a t-shirt. I know my icc is not setup correctly but I am printing just plain black text so I thought it would be ok but it came out a dirty green/brown even though the pressed page looked completely black
