WOW mugs
quasar
Re: WOW mugs
Post by quasar »
I bought a demo set, but have noticed the tape I am sticking them on with is showing up after heating and leaving a mark on the mug after cooling.
could this be too much pressure, as I am following direction for temp and time?
vB_ID:1211
vB_ID:1211
vB_ID:1210
vB_ID:1210
WorthDoingRight
Re: WOW mugs
Post by WorthDoingRight »
If that line all around the mug is from heat tape then I think you are using way too much tape - i use a 2 cm piece times 2 stuck on the short ends of the paper eg under the handle.
quasar
Re: WOW mugs
Post by quasar »
No the tape is the little bit in the second picture, I think the other marks are from paper, which is why I wondered about pressure?
WorthDoingRight
Re: WOW mugs
Have you tried washing the mugs to see if the residue comes off?
quasar
Re: WOW mugs
Post by quasar »
Will try that, just wondered why it happened.
Re: WOW mugs
I noticed that too. And it wont wash off. All i.do i lower temp down.and extend time. As coating.on them is soft.
WorthDoingRight
Re: WOW mugs
Well I have had the odd mug where the paper stuck to the mug and the residue washed off. I wondered if it was damp paper or wet ink issues. Luckily it happens so infrequently.
WorthDoingRight
Re: WOW mugs
Paul;55008 wrote:I noticed that too. And it wont wash off. All i.do i lower temp down.and extend time. As coating.on them is soft.
Well looks like these WoW mugs only WoW if you get them right :frown:
quasar
Re: WOW mugs
Post by quasar »
At the moment they are not giving me that wow factor, just ahhhhhhhhhhh!
Re: WOW mugs
WOW = Waste Of Wonga
IMHO LOL!!!!
