Foamex
RaDecal Graphics
Re: Foamex
Post by RaDecal Graphics »
Just a quick question, has anyone tried pressing direct onto foamex board.
I have loads of it but run out of polyester in trying to get my colours right.
Any idea on heat times if this is possible.
Steve
RaDecal Graphics
Re: Foamex
OK, found out myself that it does print on Foamex although my colours are still way out and the Foamex goes a little soft until cool which could be a good thing for interesting moldings.
logobear
Re: Foamex
Post by logobear »
CPM laser paper from The Magic Touch works, - 150c for about 5 seconds, - low pressure (experiment)
Re: Foamex
logobear;54781 wrote:CPM laser paper from The Magic Touch works, - 150c for about 5 seconds, - low pressure (experiment)
...and a 40% saving from for premium members.
http://www.printerowners.co.uk/magic-to ... -cpm62.htm
WorthDoingRight
Re: Foamex
Post by WorthDoingRight »
I did see in one of my sublimation catalogues sublimatable foam sheets and the blurb said that after pressing a heavy flat item is placed on the sheet whilst it cools to keep the material flat or it can be thermo formed into shapes prior to cooling. I wonder if Foamex is similar material?
