Shelf Life of a Transfer?
arko
Re: Shelf Life of a Transfer?
Post by arko »
Saying I had a design that started to pick up in sales and I started to print it more and more often, would it matter if I printed say 30 pieces which I knew I could sell over a month? I mean, have transfers a shelf life before the inks deteriorate before pressing? Or if suddenly no-one purchased that design that I had run off a batch from, still be ok to press in say, 6 months to 1 year?
WorthDoingRight
Post by WorthDoingRight »
Well depends on the type of transfer and ink. If you mean for example a light t-shirt transfer printed with UV resistant pigment ink then the shelf life is probably a very long time as the inks final home is infact the transfer.
arko
Post by arko »
I see.... thankyou.
mrs maggot
Post by mrs maggot »
there are quite a few posts on storing them in ziplock bags etc, and sure you have paper inbetween etc, but yes they can be stored, some members have stored for 6months but packed away rather than just loose
Ian M
Post by Ian M »
I keep mine a box in the dark & that seems to work quite well.
guarddog14
Post by guarddog14 »
keep mine in a cupboard , ive had problems with one set that was just text but all others have been fine
frazzle
Post by frazzle »
When you say transfer do you mean Sublimation transfers as well are ok to print off and store.
arko
Post by arko »
No frazzle... just ordinary transfer prints. Anyway, I have run off a batch of 20 of the same design and found some A4 zip-lock pouches that look similar to posting bags so no light should get to them.... lets see how it works. Thanks for the tips guys. :)
