What is a good paper to use in mug press?
SilentAlf
Re: What is a good paper to use in mug press?
Post by SilentAlf »
Hi All,
Does anyone know what is a good paper to use, for sub mug pressing?
Most will work to a pretty decent degree but personally I use the TRUPIX paper which produces really good results
I use Xpres for everything (bought through Xpres or BMS) £7.50+vat per 100 sheets at BMS if you're a Premium Member and it works a treat.
SilentAlf
Post by SilentAlf »
cool, Thank you for your answers. I'm awaiting for my printer to arrive so i will get the paper to. also does anyone have any tips on how to make sure when i print a photo that it will fit on the mug? and do i need to cut paper to size before print? sorry for the questions i am new to this :)
Trupix will give you ecelent results and texprint will give you exelent results with very high ink relase.
In last two videos i posted in video section i used trupix so you can have a look ..
SilentAlf
Post by SilentAlf »
Hi Paul,
Where would i find the video section? I ended up buying Trupix which i have have confidence in it now as you recomended it. Thank you.
i Have still not yet printed my first mug yet. i am in the middle of learning how to use photo shop to make my own templates lol
SilentAlf
Post by SilentAlf »
Thank you Paul.
frazzle
Post by frazzle »
If you are waiting for a new printer to arrive make sure the cartridges you insert are sublimation, not like me i had normal cartridges in the box which i inserted.
