What method are you using to make up acetates?
Discuss anything to do with Screen Printing.
AJLA
Re: What method are you using to make up acetates?
Post by AJLA »
What equipment are you using to print onto your acetate?
A dedicated inkjet, copier etc?
John G
Post by John G »
Minolta colour laser 2300 - quite an old printer now but gives cracking black acetates.
AJLA
Post by AJLA »
So is most of what you do solid blocks of colour then John?
For more complex designs is that when a printer is required to print with 1/2 tone dots? And maybe something I shouldn't even be thinking about at this stage?
John G
Post by John G »
Halftones are used for full colour work (photographs) and also for shading as screen printing is spot colour you need these dots to attain the different shades. Full colour work would require 4 screens made from haltones (CMYK) possie's which when printed in close registration produce the photo. Not something you should be trying if your new to printing - I'd stay clear of halftones until you have been screen printing a while - also to produce halftones on an acetate (possie) I think you need a postscript printer.
Cheers John
AJLA
Post by AJLA »
Thanks John I did think it was probably for the more experienced printer.
GoldRapt
Has thanked: 6 times
Been thanked: 8 times
Post by GoldRapt »
Hi John,
Does the laser shrink the Acetate or am I thinking of vellum?
regards
Tony
-launching july/august 2026
Greg
Post by Greg »
standard inkjet will do the half tones too. Although I'm currently in the market for a large format printer. Any suggestions?
gavtheoldskater
Post by gavtheoldskater »
epson b1100 (up to a3) with regular (as in cheap) ink on acetate from madaboutink on ebay. cheapest i've found the quantities i use.
Users browsing this forum: No registered users and 14 guests
