Hello from GR
Re: Hello from GR
Hi all,
i am new to all these and expect to find some orientation on your beautiful forum.
I am just an enthusiast (not professional) and just purchased this A4 press Flat T shirt Press 23x30cm Swing Away Digital Version
in order to make some t-shirts and especially make rock-slates with photos for gifts etc.
i would be pleased if you give me some directions because i am lost in technologies (iron on, sublimation, vinyl etc) what to use where and how!
thanks in advance for all your help
pentraks (or Frank in real life)
- CarArtz Dave
Re: Hello from GR
Hi Pentraks.
Do you have any other equipment yet?
Printer, Ink, paper etc?
Dave.
Dave.
My future Global Empire: www.carartz.com
Re: Hello from GR
I have color Laser and inkjet for home/office use (can i use them or do i need special inks or.... new printers?)
for media i have purchased several laser print FOREVER & EezWeeD sheets for dark and light garments and some inkjet sublimation sheets from coralrgraph (still don't know how to use them, attemps on rock slate epic failed)
As a noob, i have mixed everything in my mind and need to sort them out.
Re: Hello from GR
Hello Frank welcome to the forum. I think my friend you need sit down with a few cups of coffee and read the threads on here for starters. I take it you dont have sub ink in your printer.....
Re: Hello from GR
Charlie, no sub ink, just mistook the label on the sheets cover "For every ink jet printer".... misleading? maybe.
For the laser transfer i guess i am ok.
For the sublimation process, it's something i need to learn more about. I will firstly take a look on the starters threads, as you suggest, and then make some direct questions on the appropriate forum topics.
Thanx!
Thanx!
Re: Hello from GR
No problem Frank, I learnt a lot reading through all the the old posts.............
Re: Hello from GR
Welcome to the forum
You're going to need a sublimation printer if you want to print onto the slates. The current A4 supported Ricoh is the SG3110.
