Currently looking for a swing heat press (A3). Approx 20" x 15" inch. Any advice welcome.
I was looking at the Xpres model but it does seem like a lot of money at this early stage of business
Burrelly7;53154 wrote:Thanks for the replies. I've been told I will need the swing press if I do such items as Lux Panels (xpres). Apparently the clam press is awkward to use if your pressing thick items??????
When i`m doing the thick Lux Panels on my clamshell, i just roll up a tea towel into a sasuage shapeand then place the lux panel on the press. Then press for the required time and then rotate 180* and then press for another 25 seconds.
This works for me
Does the process of rolling a tea towel into a saugsage shape have a therapeutic reason or does it play an integral part in the process? I cannot from your post decide where you are sticking your sausage once rolled lol Maybe you could assist with a bit more information please.NASH;53972 wrote:When i`m doing the thick Lux Panels on my clamshell, i just roll up a tea towel into a sasuage shapeand then place the lux panel on the press. Then press for the required time and then rotate 180* and then press for another 25 seconds.
This works for me
