Opinions on my Printer/transfers/ink choice
Blame
Re: Opinions on my Printer/transfers/ink choice
Post by Blame »
Right seems like il have to wait for the CISS to be avaialable and in the meantime il use refill carts.
Justin could you possbily tell me which refill carts you have been using? and where to purchase from? thanks!
Bought them off eBay (Hong Kong) seller id is cube1113, £10.88 all in :-)
Blame
Post by Blame »
Thanks for that Justin! will be ordering mine along with a new 1500w and some inks for it!
Been having a few issues with these refil carts, nothing serious but I bought a set of 1400 carts to put my mind at rest. Wasn't sure about the 1500 carts as they were different to my usual carts. Fingers crossed the 1400 carts appear to be working ok but I'm still testing.
Did you get the printer yet?
Blame
Post by Blame »
hi Justin
Yes i have brought the printer, just waiting for the refill carts and inks to come.
What problem did u have with the cartridges?
Shall i use the pigement ink to start the printer the 1st time or use the original epson ink 1st?
Ink not flowing properly when left overnight, 1400 carts working fine.
Blame
Post by Blame »
Ah! so the 1400 works better than the so called 1500 one then? where did you get the 1400 one? thanks
You can usually get them on eBay, I use Ink-Girl but had to go through their website to buy these :-)
JSR
Post by JSR »
I bought mine from ink-girl.co.uk, too. I don't use them too much because I don't like Epson's thimble-sized cartridges but I've never had an issue with the 1400 cartridges. Now, the B40W ones, that's a different matter... :wink:
If you go to their website through www.ink-girl.co.uk you'll see a discount code for if you spend over £15. The top-left of the page shows a special code to get a free 8GB memory stick if you spend over £20. I don't think you can qualify for both at the same time, but a freebie or a discount is better than nothing.
