Hi ADP
Bear in mind that if you are doing a run of something you may have to adjust the times a little once the press is running constantly hot.
Good luck.
Pressing times for ricoh
Scotty@BMS
Re: Pressing times for ricoh
Temperature is only half the issue. If you are pressing Sublijet-R transfers for five minutes or upwards you will be beyond lucky to have serious discolourations. Hence the times provided.WorthDoingRight;51848 wrote:Well imho unless the item or ink deforms under heat then sublimation at a given temperature could be for a lot longer with minimal consequences.
So I can see no reason why you couldnt press a mug at say 170c for 3,4,5 or longer minutes as long as you have at least enough heat and time for the ink to sublimate then too much time isnt really an issue.
I would rather press at a slightly lower temperature for longer than a too high temperature.
