Polymer Mug anything I need to know?
JMugs
Has thanked: 10 times
Been thanked: 10 times
Re: Polymer Mug anything I need to know?
Post by JMugs »
Just that really.
I have an order for Polymer mugs, I have established I need a puck, but is there anything else I need to be aware of?
Unfortunately BMS are out of stock, customer needs them Yesterday, hence I will have to go to Coralgraph who I have never used, CG appear to not list the puck!
It's about the only mug I don't hold in stock ....... that'll teach me!
Janners
WorthDoingRight
Post by WorthDoingRight »
Well, I believe that the inside diameter of these polymer mugs is 73mm, which is exactly the same diameter as the cheap aluminium water bottles you can pick up in £1 stores nationwide. So if you cannot find a puck you may be able to source a waterbottle instead.
Charlie_
Post by Charlie_ »
JMugs;51726 wrote:Just that really.
Janners
Well i have used the coralgraph polymer mugs and they are great. Martin @ bms sells the pucks seperatly. I know when I went to coralgraph he several boxes of polymer that was neary 2 weeks ago now though.
WorthDoingRight;51729 wrote:Well, I believe that the inside diameter of these polymer mugs is 73mm, which is exactly the same diameter as the cheap aluminium water bottles you can pick up in £1 stores nationwide. So if you cannot find a puck you may be able to source a waterbottle instead.
They fit(ish) but leave a gap at the top as the inside is slightly tapered. You may find the top lip slightly distorts if you use a water bottle.
WorthDoingRight
bms;51735 wrote:They fit(ish) but leave a gap at the top as the inside is slightly tapered. You may find the top lip slightly distorts if you use a water bottle.
Well either you need to sell coralgraph your pucks or they need to sell you their mugs lol
Seems a right to do imho lol
Thanks for the info Martin
Charlie_
Post by Charlie_ »
WorthDoingRight;51736 wrote:Well either you need to sell coralgraph your pucks or they need to sell you their mugs lol
I have to admit that the puck I got from bms fits like a glove, having just tried a water bottle in a mug its not a good fit at all.
AdamB
Post by AdamB »
I posted this last year - may be of some use for you?
http://www.dyesubforum.co.uk/vbforum/sh ... lymer+adam
Charlie_
Post by Charlie_ »
AdamB;51739 wrote:I posted this last year - may be of some use for you?
http://www.dyesubforum.co.uk/vbforum/showthread.php?2602-polymer-mugs-first-review!!!&highlight=polymer+adam
It was on reading this in the archives, that made try out the polymer mugs Adam, as I had a rather unique idea for them. At the mo sales are slow but that said are picking up week by week.
I fully recomend any one thinking about polymer mugs to read your article Adam...
JMugs
Post by JMugs »
You lot are such a great source of info. Just need to get my customer to hold fire.
