wanted part for ciss
doe
Re: wanted part for ciss
Post by doe »
need a small stopper and small inlet bit (not sure wot they are called)
its the ink let for the feed. can you buy them from anywhere
or do i need a new full ciss.
purpledragon
Post by purpledragon »
Hi
i have a few bits n bobs from ciss systems need to know more though can you take a pic of what you need and ill see what i can do
doe
Post by doe »
[ATTACH=CONFIG]1093[/ATTACH]
cheers for the reply wot i need is 1 of the small inlet on the end of the ink feed
vB_ID:1093
vB_ID:1093
Untitled 2iiiiiiiii.jpg (89.01 KiB) Viewed 17 times
purpledragon
pm your address i think i have a couple knocking around
