Why wont it print?
Miss Angel
Re: Why wont it print?
Post by Miss Angel »
Installed drivers ect. photoshop sends to printer. printer does nothing. Document is queued but wont print.
Cheers, Emma
www.Sexxi-Sudz.com Handmade Soaps, Bathbombs and other goodies. Website designed by www.wabbittdevs.com
RogerC
Post by RogerC »
If you have more than one printer connected to the computer you might have to select which printer to use. On my set up I select 'powerdriver' for my Ricohand it's fine.
Miss Angel
it's the only printer i have connected.
Miss Angel;48223 wrote:Installed drivers ect. photoshop sends to printer. printer does nothing. Document is queued but wont print.
Cheers, Emma
If this is on a network then you may need to check the ip address. If it is connected via USB then you may have more than one installation. Go into Control Panel and delete all the printers there (remove the USB cable when you do this). Leave the USB cable unplugged and reboot, then connect the USB cable. Windows should then auto install the drivers and connect it correctly.
Can you run a test print from printers in your control panel ok? a nozzle check for example.
Miss Angel
auto detct wont work. laptop dont pick it up :-/
Miss Angel;48256 wrote:auto detct wont work. laptop dont pick it up :-/
If this via USB then it might be the USB port, USB lead or USB connector on the printer. Do other items work via the USB? ...and the printer is switched on??
Miss Angel
i don't know how but i got it sorted - few beers always helps haha. did my first mug at about 3am and it's great!. The only thing is that bold black text has browned slightly. the rest of the black is spot on tho.
All i need now is a name so i can start advertising
Miss Angel
[ATTACH=CONFIG]1064[/ATTACH] Not bad for a first go?
vB_ID:1064
vB_ID:1064
logobear
Post by logobear »
brown blacks indicate overcooking, - reduce time or temp
