Dye Sub Transfer question
- WorthDoingRight
Re: Dye Sub Transfer question
Hi All,
I cannot find any posts on here about how long a dye sub transfer is useable for.
So if I say printed a design using sublimation ink onto a piece of sublimation paper and did not use it immediately, how long would it be good for before it would fail to transfer in a press?
My mug press instructions say that after printing onto the sub paper I should wait 10 mins before transferring it but I wondered if transfers were good for only a small period of time or whether I could keep a supply of ready printed transfers for transfering later to items?
Many Thanks in Advance
i think it has been talked about on here somewhere.
i don't think there is a general rule of thumb tbh.
some ppl have had designs printed out for months and they have been fine.
i tend to press mine as soon as they are printed so never have this question
- WorthDoingRight
Well, that is at least some useful information. Thanks.smitch6;47271 wrote:some ppl have had designs printed out for months and they have been fine
I have some that I use for the rescue I work for.. that sits pre printed stored in an envelope for weeks at a time.. and it's been fine when printed..
Just make sure it doesn't get damp once printed.. so store somewhere dry and preferably airtight ?
An image can be used immediately on most sublimation papers. Only some of the high release papers require a drying time.WorthDoingRight;47270 wrote:Hi All,
Images can be used days, weeks, months after printing.
- WorthDoingRight
Well lots of useful info here, so far I have myself printed the transfer, warmed the mug press up and then printed with great results. However, it would be useful to be able to print a few spare transfers to keep for emergencies.
So thanks for all the replies.
i would store them in some sort of folder - the ones with the clear two way sheets inside - that way you can see them quickly enough but, they are kept clean & FLAT ! - just my 2p worth
i would store them in a folder - the one with the clear two way sheets inside.
Easy to see your transfers at a glance but, also kept neat, clean and FLAT !
