Ricoh GXE 3300
Paul Goddard
Re: Ricoh GXE 3300
Yes, the Powerdriver removes the hassle of working with profiles. You can print from any software and the result should be the same
Paul Goddard
Re: Ricoh GXE 3300
You can download PowerDriver and all the support documents for setting this up at http://www.sawgrasseurope.com/technical ... sublijet-rPaul Goddard;47005 wrote:Ok that sounds better think ill sort it that way thanks
Paul Goddard
Re: Ricoh GXE 3300
Hi Guys reloaded printer and installed the powerdriver. When i have just done a print it seems more clear like a standard print i thought sublimation was dull on paper until it was pressed on ??
Re: Ricoh GXE 3300
It is duller than when it is transferred, but not absent from colour entirelyPaul Goddard;47286 wrote:Hi Guys reloaded printer and installed the powerdriver. When i have just done a print it seems more clear like a standard print i thought sublimation was dull on paper until it was pressed on ??
Paul Goddard
Re: Ricoh GXE 3300
Hi Martin thanks for that all ok. think im going to ring you and try your sublimation paper.
Users browsing this forum: Google [Bot] and 10 guests
