Vinyl not sticking
plugy
Re: Vinyl not sticking
Post by plugy »
I am new to this but how long do you press vinyl for.
I have tried my first attempt at 20 seconds then 30, 40, 60 ,60 but each time the vinyl seams to lift and stick could it be the type of tee poly or cotton but i thought i doent matter with vinyl?
Renniwano
Post by Renniwano »
I press mine at around 12-15 seconds.. what temperature are you using ??
Renniwano
Post by Renniwano »
Also, if you're using a cold peel and peeling whilst hot, that will remove the vinyl...
What make of vinyl are you using ??
RogerC
Post by RogerC »
entirely depends on the type of vinyl....unless you know what you are using and the required temp, pressure, time and hot or cold peel you'll be making mistake after mistake.
plugy
Post by plugy »
it is what i got when i bought the press, is there a way to tell if it is hot or cold peel?
Are you sure this is t-shirt vinyl and not sign vinyl?
RogerC
Post by RogerC »
why not ask whoever you bought it from what type of vinyl it is.........job done.
Bison 28
Post by Bison 28 »
Bin it and buy some new, problem solved, as long as the heat press is working properly.
Scotty@BMS
Post by Scotty@BMS »
Bison 28;46699 wrote:As long as the heat press is working properly.
Excellent point. You should check the temperature of your press with an infrared thermometer. It may well be telling you porkies as to what temperature it is really at.
RogerC
Post by RogerC »
Scotty@BMS;46700 wrote:Excellent point. You should check the temperature of your press with an infrared thermometer. It may well be telling you porkies as to what temperature it is really at.
Could be a bit of a waste of time really Scott unless plugy knows just what vinyl is being used.
