Hi i have just bought the new ricoh sg 3110dn from bms, i finally got it installed properly after 2 attempts i have it installed on my pc running windows 7 ultimate, i also have an imac which i want to install my new printer on my question is if i am using the printer on my windows system can i use the network on the printer to use with my imac as i use the usb cable for the pc, if anyone knows of a tutorial on how to do this it would be greatly appreciated.
thanks malcolm
ricoh printer
Re: ricoh printer
A printer can be connected via two leads. We have laser printers connected with USB and Ethernet depending on which route we are printing. I don't see why you can't set the printer up as a network printer from your iMac and a USB connection on your PC. The iMac won't know about the PC connection and the PC won't know about the iMac connection as they will print via different ports.hakuna;46560 wrote:Hi i have just bought the new ricoh sg 3110dn from bms, i finally got it installed properly after 2 attempts i have it installed on my pc running windows 7 ultimate, i also have an imac which i want to install my new printer on my question is if i am using the printer on my windows system can i use the network on the printer to use with my imac as i use the usb cable for the pc, if anyone knows of a tutorial on how to do this it would be greatly appreciated.
thanks malcolm
