ciss... really that bad?
gstk
Re: ciss... really that bad?
Post by gstk »
Paul;42369 wrote:Ciss is great when its work ok. But when it goes bad then you pray about refillables back :-)
Some decent ciss on ebay btw...
Crikey Paul - wasnt long ago you were telling me Ciss was fantastic and you wouldnt consider anything else and it never goes wrong ;0)
Personally I would never touch a Ciss system again EVER. Ricoh cartridges all the way.
Nope.it was not me. How can i say that if i use refilables myself...?
gavtheoldskater
Post by gavtheoldskater »
well, i weighed it up and i went with a ciss (at a very good price) from cityinkexpress my thinking being that i may as well try it myself because if its OK it will be the least faff system - maybe!
i'll report back how i get on.
gavtheoldskater;42529 wrote:well, i weighed it up and i went with a ciss (at a very good price) from cityinkexpress my thinking being that i may as well try it myself because if its OK it will be the least faff system - maybe!
nice one! very good quality ciss! I had it for about a year and a half before it when tits up :)
doe
Post by doe »
can anyone tell me where i can get refillable cartridges for
sublimation ink for the epson b1100
Got mine off eBay for around a tenner, Coralgraph may stock them as well.
doe
Post by doe »
seen them on ebay but not sure which to go for
none seem to say its ok for sublimation
cheers for the answer tho
Should all be ok for subli inks. Can't remember which seller I bought from without looking, can check tonight. Never had a problem buying from different sellers over the years.
doe
Post by doe »
ok cheers justin would u let me know which seller when you get chance
gavtheoldskater
i'm pretty sure if you do a search for ciss on here you will find someone who posted the name of a good ebay seller, ink-girl i think the seller was. mind you i've got a set from bestbet_4us that i'm perfectly happy with.
as mentioned above i got my ciss from city ink. i emailed them via ebay and got it for a very good price. less than their website. touch wood its working well for me, bit of a faf to set up but i like the simplicity. far easier than dealing with cartidges.
