Ricoh printer profile problems..........
JSR
Re: Ricoh printer profile problems..........
Post by JSR »
Janners Mugs;45718 wrote:You could be on to something... I'll watch, hope it comes off!
Hopefully, once the patent expires, we'll see a lot of competition in the dye-sub ink market. That'll entail a lot of work for us end-users to sort out the good from the bad, but it should result in some much cheaper ink.
It's seems scandalous that Sawgrass charge £240 for four inks (100ml of each) which you can buy for about a tenth of that direct from China. No wonder they're so keen to protect their patent and to put others out of business. For what little work/R&D that they do, they must be raking it in.
The point I'm making though is that, when the patent expires, this kind of cheap ink will flood the market and there are bound to be both good and bad variants just like there are with other third party inks. Sorting the wheat from the chaff will be an experience and a half. One thing's for sure, though, it's currently much easier to put third party ink in an Epson or Brother (through refillables or a CISS) than it is through a Ricoh. I'm sure that will change but those people who bank on Ricoh probably won't have the freedom and options of those who use Epson and Brother printers. Perhaps that's the real reason for the current "advice" to buy into Ricoh?
BigAl
Post by BigAl »
A good lawyer could drive a horse and cart through that ruling I am convinced.
JSR
Post by JSR »
BigAl;45720 wrote:Why not large format please answer that, the technology is identical, is it the snake oil they add lol. The difference is if a head goes down on my versacam I get a bill for £1110 as I had last week so I am sure if the ink was damaging no one would use it in large format machines.
There's been a little bit of talk along this line just recently when Sawgrass announced support for a 24" Epson printer (which they class as "desktop"). The printer itself costs over £2000 and the ink (through Sawgrass) doesn't work out much cheaper than it would for a regular desktop printer.
Is anyone going to risk a £2K+ printer with expensive dye-sub ink that's known to have problems with the cheaper printers? If you use a £25 printer and the ink stuffs it up, you've only lost £25. If you use a £2K printer and the ink stuffs it up, then that's it really...
JSR
Post by JSR »
BigAl;45722 wrote:A good lawyer could drive a horse and cart through that ruling I am convinced.
That's what we were all hoping with the TOG challenge. Pity they bottled out.
BigAl
Post by BigAl »
Got paid off probably. :)
