yes they are standerd bathroom tiles that i coated with the poly coating fluid then pressed the image on.hidehi;44823 wrote:Oh my, well done you! Are they tiles? I've just checked the tracking for my parcel and its now out for delivery, so hopefully it should be with me anytime. I can't wait to try it.
Swing Away 38 x 38 Heat Press
personalised_sublimation
Re: Swing Away 38 x 38 Heat Press
Wow that's amazing. Please excuse the ignorance, but what is the image made of and what is poly coating fluid? This is all new to me!
- mrs maggot
http://www.coralgraph.com/sublimation-c ... -polyester this is the stuff
yep thats the stuff indeedmrs maggot;44827 wrote:http://www.coralgraph.com/sublimation-c ... -polyester this is the stuff
- mrs maggot
hideihi & ps - might be worth making a new topic in the dye sub bit, rather than on a wanted page :biggrin:
Haha, yes probably a good idea Laura! Thanks for the linky to the Polyester stuff
how did you do that? whats the process involve?personalised_sublimation;44824 wrote:yes they are standerd bathroom tiles that i coated with the poly coating fluid then pressed the image on.
get standerd tiles and coat with the poly coating leave them to dry then stick them in the oven at 210c and leave them for 10 mins then let them cool.Paul;44899 wrote:how did you do that? whats the process involve?
then press the image at 365f for 400 seconds tile facing down.
sounds simple enough
i might do that if i find spare £25
Out of curiosity have you done any tests for washing, cleaning etc ?personalised_sublimation;44900 wrote:get standerd tiles and coat with the poly coating leave them to dry then stick them in the oven at 210c and leave them for 10 mins then let them cool.
