When using heat transfer vinyl, I've read that its good practice to sandwich the t-shirt being pressed between two sheets of paper ie. paper, garment, paper. Can someone help me out please by telling me what paper I should use and also where I can buy it? Some have mentioned a teflon sheet, whilst others say silicone paper.
Also, having read forum threads and watched youtube videos etc, I'm worried about causing permanent pressing lines in the t-shirts. I will be using mdp hotflex so how likely is it that the edge of the mylar(?) backing sheet could cause lines? What can I do to prevent these?
Am feeling a tad overwhelmed at the moment as my t-shirt order is due to arrive tomorrow and I can't afford to have them go wrong. I do have a couple of tees that I can practice on though so any hints & tips in advance would be very welcome! Thanks so much :biggrin:
