New Cutter has arrived! MH-721
Review new equipment, blanks etc.
Has thanked: 13 times
Been thanked: 12 times
Re: New Cutter has arrived! MH-721
TBH I've had very little use, it just sits here at the moment. I bought it for a particular customer and after the first couple of jobs they decided to go the screen print route....having let me buy vinyl and shirts for them, thanks guys.
When in use it seemed to do the job fine. Not on a par with your Roland or Graphtec and I'd very much like to get back to something like that but I'm not doing any vinyl/transfer route right now.
I might have a manual, will have to take a look. Can't remember the eBay seller, may have been that one, again I can try and check. The seller I dealt with was a major pain in the backside and I'd never recommend him at all.
If your bought of this same guy as me justin his nick was anothergoodseller or something like this. Contact him recently with question and had answer to my email within 24h so i might be the lucky one :-)
Yeah, I remember when I bought it you mentioned it was the same guy. I know you had a good experience with him but mine was nothing short of awful. I ended up having to speak to him on the phone and he was extremely rude.
TITCH
Post by TITCH »
Hi Guys!
isn't a bitmap the ideal thing for cutting on a plotter, or a vectorised image? I always relate the way that a blade cuts on a plotter as the same layout as those colouring books kids get at Christmas, basic outline images.
I use Signlab, admittedly all of my work is set out in Signlab then either cut from that direct, or export Ai files to print AND cut on a Gerber Edge using the Omega programme....I certainly don't understand the science behind much of it, but I just know the two programmes I use all the time and where to 'click'
Plotter blades have different angles for different materials, and 'drag knife' blades have always worked for me..in fact, my Ioline plotter, at 17 years old, is spot on!, no frills, forwards backwards, left & right..not the same work as a lot of folk on here, but I bet I've put hundreds of miles of vinyl through it, and the Gerber plotter..I came to the conclusion 20 years ago, that fast isn't the best, it's the quality of the cut..my machines are 'plodders' and perfect for my work.
Hope I've not sabotaged the topic here..just trying to add some imput..tell me to shut up if need!
Titch
RESTORATIONS FINAL TOUCH
