Swing Away 38 x 38 Heat Press
personalised_sublimation
Re: Swing Away 38 x 38 Heat Press
NO LONGER NEEDED.
hi im lookin for 38 X 38 swing away heat press to use along side my mug press so i can do more stuff for the sophie lancaster foundation ( Registered Charity Number – 1129689 )
if you have one for sale please get in contact with me and let me know what you have.
thanks
carl.
thanks
carl.
Hi Carl,
It just so happen's I am putting an ad together to go on ebay at this moment. I have an 'Adkins' 38x50cm 'Deep Impact' swing head press for sale. If you have done your homework with regards to heat presses then you will know that these are simply the best on the market and made in the UK! My press is larger than what you have specified but the extra room does enable you to do more items at once, which in turn cuts down on production time if you are doing larger print runs. Also the 'Deep Impact' press gives you more flexibility when it comes to printing different items because you can print onto items up to 17mm deep which you could not on the ordinary swing presses.
My Press is like new having only been used a handful of times. All of my customers in the retail trade were only interested in my mugs so the press never got used. To purchase this new (please see link) will cost you £1,194 including the dreaded vat. I will be offering it on ebay for £795 but would accept £750 if it was of interest? If you would like to see some photos l can email them to you. A link to the press is http://www.themagictouch.co.uk/hardware/heatpress.htm.
Regards,
Kevin.
Regards,
Kevin.
Can I ask which press you decided on please, as I'm also looking into buying a 38cmx38cm swing away
i got one cheap for £130hidehi;44638 wrote:Can I ask which press you decided on please, as I'm also looking into buying a 38cmx38cm swing away
this is the one i got off them for £130.
[ATTACH=CONFIG]964[/ATTACH]
- vB_ID:964
- photo (2).JPG (53.16 KiB) Viewed 20 times
Thanks for the info. I actually ordered one last week, due for delivery today and it looks identical to the one you posted! Hope its working well for you.
well this is what i have done with it so farhidehi;44820 wrote:Thanks for the info. I actually ordered one last week, due for delivery today and it looks identical to the one you posted! Hope its working well for you.
[ATTACH=CONFIG]965[/ATTACH]
- vB_ID:965
- photo (4).JPG (37.74 KiB) Viewed 20 times
Oh my, well done you! Are they tiles? I've just checked the tracking for my parcel and its now out for delivery, so hopefully it should be with me anytime. I can't wait to try it.
