chromalux metal
bassqee
Re: chromalux metal
Post by bassqee »
Anyone know where to get the smaller chromalux metal panels - can find 8 by 10" ones but nothing smaller in the uk.
Colin
Re: chromalux metal
http://www.sublimetal.co.uk/?wpsc_produ ... nium-sheet
I'm just about to order from here, maybe not the same as you're after?
bassqee
Re: chromalux metal
Post by bassqee »
Got the sublimetal - its nice, but not in the same league as the chromalux metal.
Re: chromalux metal
Where do you normally get the chromalux metal? What's the difference between these two?
bassqee
Re: chromalux metal
Post by bassqee »
I get it from novachrome - but the smallest they do is the 8 by 10.
Chormalux is thicker and gives much better colours compared to the sublimetal.
bassqee
Re: chromalux metal
Post by bassqee »
No-one have any ideas - anywhere international thats recommended? Wouldn't mind the shaped ones too.
Colin
Re: chromalux metal
bassqee;44503 wrote:No-one have any ideas - anywhere international thats recommended? Wouldn't mind the shaped ones too.
Colin
What size do you want? I'll see if the European distributor does other sizes close to what you want.
bassqee
Re: chromalux metal
Post by bassqee »
thank you!
they do a 7 by 5" panel and a 8" circle.
Re: chromalux metal
bassqee;44528 wrote:thank you!
Okay, I'll see what I can find out.
AdamB
Re: chromalux metal
Post by AdamB »
Do you supply normal metal circles Martin?
(sorry - I'll be honest, I'm too idle to look).
