Colour Problems Printing to Flock Using Robo Master - ICM Profile Problem?
Re: Colour Problems Printing to Flock Using Robo Master - ICM Profile Problem?
mysticalvibes;44136 wrote:Hi guys, Thanks for all your help. Tried cutting the outline using the craft robo but must need a new blade as it only cut through the backing sheet! Had to cut it again with a craft knife. Getting there slowly but surely.
Davy
SubliFlock doesn't have a backing sheet - it is a piece of flock without the clear plastic backing.
... Or you mean paper carier sheet? If so you need to cut it fluffy side up :-)
Paul;44149 wrote:... Or you mean paper carier sheet? If so you need to cut it fluffy side up :-)
I think perhaps we are talking about different products. SubliFlock doesn't have any backing to it at all (no clear plastic backing, no paper carrier sheet) - at least the SubliFlock we sell doesn't. With the Craft ROBO we cut into the smooth back with the pink blade attachment and this cuts out the shape.
here is what my look lik
