Hi
What is the best tack of application tape for multi layered vinyl designs ?
Also what is the best application tape to use as an all rounder and where is the best place to buy it from in the UK please.
Advice on what application tape to use for multi layered vinyls
Re: Advice on what application tape to use for multi layered vinyls
Is this for t-shirts? As the vinyl comes on a backing already you can just keep overlaying and pressing. I used to do this quite a lot, reduced the time a little and always did a final press to finish things off.
I also used to buy backing sheet from Dorotape and Xpres for applying printed transfers.
Hi Justin thanks for the fast reply
Yeah its for t-shirts and also to sell multi layered logo's ect to customers
The Xpres stuff was fine, Dorotape I used their print and cut materials which were great through large format. Worth getting a sample of the backings.
I would say so but take a look at Dorotape.
