Light Photos
Re: Light Photos
If you print out the same photos on a normal printer/inks from PSE, do they come out correct or too light?
When you "print colours and text and it comes out fine." how do the colours and text compare to the colours you actually see on your screen?
John G
Re: Light Photos
Post by John G »
When you set up the powerdriver did you have to take your PS elements back to factory settings - I'm sure I read somewhere that this had to be done for the powerdriver to be installed properly.
Ian Mc
Re: Light Photos
Post by Ian Mc »
Silly question, but what substrate are you pressing onto? I know the time and temperature sounds right - but for what? :confused:
Also, there's a useful guide on Sawgrass' website about best settings for PSE...
http://sawgrasseurope.indigofiles.com/t ... -WinOS.pdf
Re: Light Photos
North guy;42215 wrote:Cheers guys, im using photoshop elements and the power driver proper;y installed so god knows what im missing lol
If you open the image in something else, such as Word, does it print okay via PowerDriver? If so the PSE is doing something extra to the image before printing.
