Latte mugs!!!!!
Re: Latte mugs!!!!!
This should be stickied!
AJLA
Re: Latte mugs!!!!!
Post by AJLA »
you are brilliant at this sort of thing Paul.
Perhaps there should be a "Paul's Tutorial" section here.
purpledragon
Re: Latte mugs!!!!!
Post by purpledragon »
paul youre a genious now how do you stop the bloody mug from slipping out the press grrrrrrrrr
Re: Latte mugs!!!!!
Thanks guys :-)
Is this horisontal press brett? If so how about little pencil sticked to the side of the mtal frame? It will stop them to slip out.
purpledragon
Re: Latte mugs!!!!!
It is horizontal paul yes the problem is it doesnt come all the way out just moves slightly so top to bottom prints are a bit of a problem i couldnt do the image you have used in your example but a logo for example would be fine the pencil idea is a good start but doesnt quite do it i did wonder about dismatleing the press and turning the mug press bi8t round somehow but thats for a day when im a bit bored
John G
Re: Latte mugs!!!!!
Post by John G »
Well done Paul, you have a knack of making something very complicated look very easy - you should have your own video instruction section on the members part of the forum :wink:
Re: Latte mugs!!!!!
Not bad idea john ;-)
Re: Latte mugs!!!!!
:cool:
AJLA
Re: Latte mugs!!!!!
Post by AJLA »
AJLA;41530 wrote:you are brilliant at this sort of thing Paul.
Well done Paul, we will all be making requests in a minute!
Re: Latte mugs!!!!!
Thanks mandy. I thought video might be more helpful :-)
