BMS glass photo frame
Mattie
Re: BMS glass photo frame
Post by Mattie »
Hi
I don't suppose anyone has got an image of the glass photo frames from BMS i could use on my site etc http://www.printerowners.co.uk/sublimat ... -frame.htm
For the life of me i can't get a good enough photo of it with it basically having a mirror finish, also the fact i'm rubbish at photography. (really need to find a photographer).
Matthew
give me that job then :)
If you want i can photograph it for you.
Mattie
Post by Mattie »
might have to Paul, i can't seem to get good enough photo of it i just keep getting reflections in it haha
Matthew
there is few tricks... do you use flash with it? if so is it one that pop out straight from the camera?? trick is to direct light from other direction then your camera.
Mattie
Post by Mattie »
I've got one of those photo studio kits off ebay, where it folds out in to a photo box with 4 different backdrops and two lights on stands.
I use just a normal digital camera i had at home, i've tried with flash, without flash both lights on and flash etc.
I just always seem to get a reflection in the glass or shadow
Matthew
Switch flash off. Go to manual mode. Set your apeture.for the lowest number you can. Ie.2.8
Shutter speed for 100.
If still to dark rise iso up. Best thing to do is take your tent out so you hav natural light.
Mattie
Post by Mattie »
Thanks for the help Paul, think i've managed to take an ok picture www.iwantitpersonalised.com/glass-photo-frame
i'm no photographer though haha
Matthew
not bad. but i can see you better in photoshop ;)
btw... how those frames print?? any good?
Mattie
Post by Mattie »
Thanks, i use corel draw but still learning most of it haha.
They a really gud to print and the finish is spot on.
Matthew
