Keeping it cool
LazyCarrot
Re: Keeping it cool
Post by LazyCarrot »
Just testing the water on this one...
Curious - What is your preferred method of cooling down mugs after you've printed them?
Just leave them to cool down.
Assist cooling with a Fan.
Dunk in warm water.
Some other method.
The demo's I've seen all dunk in water but - i've heard this can lead to crazing of the glaze inside the mug (presumably due to the water being too cold), and I just wondered how people in the front line had fared and which option you found best to go with.
I gather that cooling down speedily is advisable to prevent the ink from bleeding - is that correct too?
And if so is it more relevant if the print runs top to bottom rather than within a border?
:cool:
I'd rather have a bottle in front of me than a frontal lobotomy
jennywren
Re: Keeping it cool
Post by jennywren »
I use a fan, at least I don't hear the noise when I use to dunk them
Renniwano
Re: Keeping it cool
Post by Renniwano »
I use a fan too.. but have left the odd one to cool on their own..
Andrew
Re: Keeping it cool
Post by Andrew »
Most cool on their own for us as most designs don't have an issue with bleeding. It certain dark/bold colours with a white background that can catch you out. Where we do cool it's room temp water as it drops the heat down instantly. Found a fan takes a bit longer on the designs that do bleed.
John G
Re: Keeping it cool
Post by John G »
Fan here too - never go back to water as even at room temp we had problems.
AJLA
Re: Keeping it cool
Post by AJLA »
I used to dip but now I don't, fan or just leave it to sit
Reg
Re: Keeping it cool
Post by Reg »
Cool on its own unless the weather is hot then I use a fan.
Re: Keeping it cool
I still dip in room temp water, tend to notice a very slight bleed/blur if left to air cool.
logobear
Re: Keeping it cool
Post by logobear »
just sit
mrs maggot
Re: Keeping it cool
Post by mrs maggot »
now air cooled all the way esp on designs with just black on as that seems to be the one that bleeds the most, esp on thicker / bigger mugs
