placemats wated
jennywren
Re: placemats wated
Post by jennywren »
I'm looking for place mats 11 inches across and 9 in depth, cork based if possible, if I can't get these, then the biggest size available will do, but need to be corked based. cheers
Re: placemats wated
You realise these will have to be printed on an A3 printer? This is a strange size so I doubt they would be available 'off the shelf' but could be custom cut (and very expensive!)
JSR
Re: placemats wated
Post by JSR »
Listawood sell these ones : http://www.listawoodtradesupplies.com/i ... d=&pgnum=2
They're 300x225mm (which is, what, 12x9 or thereabouts). I don't think they're cork backed.
BMS do the slightly larger UniSub 312x250mm (12x10 ish). Not cork backed either. At this size, UniSub placemats have a habit of warping.
Someone else might know a cork supplier for the backing. It's always been a problem with placemats and coasters - the backing isn't available separately from our normal suppliers, no matter how often it's brought up.
Re: placemats wated
I've had a play with cork backing, not bad when you get the hang of it but a little time consuming ;-)
