Problem Patchy print paper rippling
Dezignwar
Re: Problem Patchy print paper rippling
Post by Dezignwar »
Hi,
I dont know if anyone has any advice.
I am new to Sub and learning as i go, i have not been having many problems, however i started having a problem last night.
When i press an item the transfer paper goes rippled and the print then comes out patchy if that makes sense.
I have a an Epson SX415 with bulk system with Xpres transfer paper
Settings are 300dpi matt finish paper
This has happened on a Polo shirt (Xpres Sub) and on metal blanks (busniess cards - BMS white)
Hope this is enough info for someone to help.
Oh press was at a medium pressure for 30 sec. 185 deg.
purpledragon
Post by purpledragon »
Paper .... theres a thread on this you might want to read titled trupix and printers this could be a problem
also id say 60 seconds med pressure 190 deg
