Latte mugs!!!!!
Re: Latte mugs!!!!!
needing some more help guys i have corel draw , and im trying to do an 17oz latte mugs , is there anyway of fitting a square image on it?!?! been trying to curve the image for days but just cant do it , really need some help
Re: Latte mugs!!!!!
have you got photoshop??
2min job.
2min job.
Re: Latte mugs!!!!!
ok. little tutorial in 5 min. watch this space
Re: Latte mugs!!!!!
1.
Open empty page.
2. click "new layer"
3.
open your image. Copy it to empty document so you can work on it as a layer.
4.
if your image is horizontal then flip it about 90 degree. is easier to do it this way.
(ctrl+T and then right mouse click on picture. rotate 90. if done click enter.)
5.
right
you half way
now go to your filter>distort>shear...
you will see window pop up with line. click on the middle and curve it
when happy with your curve click ok. your image will turn in curve.
6.
now you need to turn it back to normal
so click ctrl+T again and rotate it back.
7. now your picture back to normal. hit enter so transfer border disappear.
8.
now go to: edit>transform>perspective. border will appear again. click one of the top corners and move your mouse to the right/left. image will transform.
9. when happy hit enter.
you done!
Open empty page.
3.
4.
5.
right
you half way
6.
8.
you done!
Re: Latte mugs!!!!!
No problem. Hope thos will help you.
