Ink Collection Unit
MugMan
Re: Ink Collection Unit
Post by MugMan »
One other issue is do you turn the printer off, as everytime it is turned back on it will do a head clean. Mine is left on 24/7.
TonyM
Post by TonyM »
Hi John,
I havent done ANY head cleans or flushes?
It does seem a bit excessive, the waste? Does it not?
Ahhh just read that from Mug man as it is on a seperate page.
I DO turn the printer off each use.
Do you think that perhaps I am doing a head clean 3 or 4 times a day then?
This would be very usefull information if proven true.
Any others have ideas?
Haze
Post by Haze »
TonyM;41234 wrote:Hi John,
I've just bought this printer and the guide does state it's best to leave it on all the time, it goes into an energy saver" mode
John G
Post by John G »
If I need to use my printer it gets switched on and is left on all day, until I close up, then it gets switched it off. If you switch it off after every use your'll be wasting ink as it goes through a maintenance routine every time you switch it on.
TonyM
Post by TonyM »
WOW!!!!!!!!!!
That is a real eye opener!
Many thanks Haze for pointing out that it goes into a power save mode and also Mug Man and John G for highlighting this.
I must admit there seems to be a fair bit of whirring and what not when I "crank it up" No wonder i have so much waste?
Well, one lives and learns. Just need to spens another couple of hundred quid on ink then.
Thank god i found this forum.
I will make some money ONE day, I will make some money ONE day. LOL
Users browsing this forum: Baidu [Spider] and 4 guests
