Converting an image to a vector format
Re: Converting an image to a vector format
I have been given a very poor image to print in vinyl. John (stitch up) my partner is away and I usually leave all of this to him. How do I convert the image to vector format? I have coral draw. Sorry to sound blonde.
I hope these are of help.
http://www.corel.com/content/pdf/cgsx3/ ... s/dr_4.pdf
http://designertoday.com/tabindex-6/tab ... fault.aspx
Jack.
Jack.
Thanks so much. I will have a play now to see how I get on. I really must learn this side of the business. Thanks again I will let you know how I get on
Angie - if i can do it from scratch ( bitmap>vector)..you can no probs.....its easy once you do it 2/3 times !Angie;40640 wrote:Thanks so much. I will have a play now to see how I get on. I really must learn this side of the business. Thanks again I will let you know how I get on
You can try online tool called magicvector
I think you might mean "vectormagic.com" Paul.Paul;40642 wrote:You can try online tool called magicvector
Jack.
If it is a very poor image as you say I had a similar problem some time back. I tried all sorts of solutions and admitted defeat so put it to members of another forum I'm on for sign makers. The answer came back 'you can't polish a t*rd'...(american respondent) so having spent hours trying to resolve the issue I gave up.
A lot depends on the size of the image you have to work from. Just how small or 'fuzzy' is the image?
Vector magic is good but it still can't make a good image from a poor one.
[INDENT]If at first you don't succeed, read the manual.
[/INDENT] I love this quote Jack Im alergic to manuals
I've emailed you - if you need a hand reply with an attachment and i'll see if I can help.
