rhinestones again
Discuss other print methods.
Re: rhinestones again
Corel plugin for rhonestones look great but licence is taking a p! Iam not going to pay £50 only for been able to install it on my pc once. If something goes wrong with hdd or i decde to do little.clean up money goes out the window. If licence will chqnge then i will buy it.
bigj2552
Post by bigj2552 »
Paul;40299 wrote:Corel plugin for rhonestones look great but licence is taking a p! Iam not going to pay £50 only for been able to install it on my pc once. If something goes wrong with hdd or i decde to do little.clean up money goes out the window. If licence will chqnge then i will buy it.
corel marco its $49.99 = £31 approx with the restictions you mentioned
same price as your funtime.
difference with funtime pro is dongle right ? = $69
difference with funtime pro 2010 = $98 ???
After doing some bits today with funtike i must say ot does what ot says on the tin. Bit hard to wrk out but work hreat. Now licence hanged and alfor extra $10 you xan have cd. So is worth it imo.
Iam going to show of with my first rhinestones attempt tonight :-)
just done my first template.
results posted here: http://www.dyesubforum.co.uk/vbforum/sh ... ad-)/page3
chongsta
Post by chongsta »
Im toying between the normal version and the pro version!
Paul, you're using the normal version yes? can you see any reason i should get the Pro version compared to whats in the normal version?
also, the shipping of the Pro version is $60 !!! rip off big time for a dongle and a CD, the proper price comes in at £98 all in.
The normal versions terms have changed,
Valid on 1 computer
Can be transfer to another computer (3 times only)
Valid for the current software version
Valid if you re-install the software
Valid if you re-install an operating system
The activation process require a Internet connection
Does this mean i can use it on 2 pc's at the same time? (home and work) or does it mean i can only use it upto 3 times on 3 PC's? or one?
I can use my Versacamm and Illustrator to cut, so i dont need the cutting option at all and im not even sure if my Roland is suppported anyway.
Whats anyones opinion on this? should i just bite the bullet and go for the pro version and be done with? I assume i can use the Pro version on 2 PC's but of course only with the bleeding dongle!!
anyone :) ?? argggggggggg
Dave
Hi! I dont know what else you would need as I done all my design with few mouse clicks :) I know that if you want to use other functions of this software then you need to upgrade to deluxe version. but this is for things like auto vector, w.y.s.i.w.y.g and other useless stuff that you wont need for rhinestones. its for people that do lot of craft things... Funtime cant cut any way buddy. what you do is exporting to PLT (cutter language format) or winpcg and then cutting from your usual software. after licence change I would recommend the funtime rhinestones version.
regards to licence i dont think you would be able to use this on 2 pc's. you would be blocked. new licence mean that when you have some trouble and need format your hdd or upgrading your pc then you can install your licence up to 3 times.
dont know if anyone mention this before but there is fantastic plug in for corel that people use for rhinestones. its called LEDtool4. $24.95.
Image Image
Image Image
Image Image
bigj2552
Post by bigj2552 »
for gods sake lol.....my brain is fried enough trying to decide which one to go with.....i get my mind set and....something else pops up....
cheers paul
johnny
I never used this ledtool4 but quite few people do use it. but as I said before... As licence changed then you can go for funtime. simple to use and you can do nice mock ups too if you need some for website or to show customer...;)
here is quick one for my design...
chongsta
Post by chongsta »
this is madness! I need the program on my work PC during the day to make the templates and i need the program on my home PC for the night when i want to do designs!
Ive never come across such an incredibly stupid license in all of my days on the web. Im off to grab Corel and use that plugin that pauls recommended...cheers Paul
Dave
