Advice needed
scottenti
Re: Advice needed
Post by scottenti »
I am new to this sublimation printing. The question I have is I have a epson 1400 printer with normal ink in, is it possible to convert it to sublimation inks?
if not I will have to buy another printer
Re: Advice needed
Yes you can change the printer over. You can use refil carts or a bulk ink (CIS) system. I would print a few colour blocks to make sure the old ink is through and the sublimation ink working.
scottenti
Re: Advice needed
Post by scottenti »
Thanks for that at least I dont have to but another printer :wink:
Re: Advice needed
...and free to download and use profiles for the Photo 1400 using Artainium ink are available from Sawgrass:
http://www.sawgrasseurope.com/technical ... c-profiles
