hi
Matt
Re: hi
Post by Matt »
hi my names matt, i recently bought a mug press package to start with with the intensions to go onto making other things like tshirts etc.
although ill probably purchase a better press first, mine keeps leaving slight fades at the bottom of my images :redface:
DS Designs
Re: hi
Post by DS Designs »
Welcome Matt, it's going to take a few wasted mugs until you get the correct time and temperature, start off at 180c for 180 seconds and see how it comes out :-)
Dave
Ian M
Re: hi
Post by Ian M »
Greetings Matt :biggrin:
Re: hi
Hi Matt and welcome to the forum :-)
DSF Admin
Re: hi
Welcome Matt - the fade at the bottom may be because you mugs bevel at the base. Try leaving 3 or 4mm gap top and bottom and see if that helps.
Matt
Re: hi
Post by Matt »
bms;38704 wrote:Welcome Matt - the fade at the bottom may be because you mugs bevel at the base. Try leaving 3 or 4mm gap top and bottom and see if that helps.
worked thanks
