EPSON 1400 settings
Re: EPSON 1400 settings
when i had my D88 everything was "open" on cd. no registration needed.
Sure I'm just being dim but only options when I inserted CD (that came with printer) were "easy install" or "custom install". I just selected easy. Can't see anything anywhere for ICC profile - sorry!!
so i think it was installed for you already then
what software do you have?
The ICC profile will not be on a CD from Epson
It will be provided by the ink manufacturer or seller you bought from (if there is one available for your ink and printer)
If you bought the ink separate from the printer, and do not have an ICC for the inks, then getting Paul to make you one is your best bet
Ink bought seperately and no ICC profile supplied. Have emailed seller to see if I can obtain one. Just another question - I produce all artwork in CorelDraw not photoshop - will that affect ICC? Also I run another A3 and A4 printers (with normal inks) would downloading an ICC profile affect the way/colors they print as that would cause me problems
Sorry for all the dim questions and thanks for everyones help
Have you read the files on this link? Many questions can be answered by reading the files...bms;38030 wrote:Everything is available to download here:
http://www.sawgrasseurope.com/technical ... /artainium
