Doming - Anyone tried it?
Re: Doming - Anyone tried it?
I do a lot of doming, anyone thinking about it , the only tip i can give is get a UV light scource for curing as humidity in the air causes blisters
how long does it take to cure when you use UV source?
thanx
thanx
The real question must be how big a UV light source, in a bed of some sort with a lid or just a light suspended. A4 or A3.?
@Paul , i leave it under for 25-30mins
@GoldRapt , i only use A4 , my uv light is attached to a black sink basin 8) ,
i made myself , the reason being they are too expensive for what they are,easy to make your own
I have two 8 inch tubes
alan1image
Not sure if the UK have these but been using self adhesive doming stickers here they come in a range of sizes 25mm, 76x25mm, 64x19mm and 25x25mm the most popular sizes.
I use the liquid resin and use a uv curing machine works out very cheap to do.
Online
Just bought a load of keyrings and there's a small recess when the insert is put in, I wonder if this gap could be domed?
cant see why not
Have you got your doming kit yet justin???
Online
No, not sure where to start just yet, single/double epoxy...uv/heat curing....
