Help with choosing sublimation printers,
sensor
Re: Help with choosing sublimation printers,
Post by sensor »
Hi All,
I'm looking for a sublimation printer, not sure which one to go with,
I'm looking to spend no more than £150,
I will be doing sublimation mugs with this.
the printer will need to be compatiable with a ciss,
Any help would be good
Cheers
Hi paul. B1100 is supported model and it cost under £100 now. GreTets benefit is it can print up to a3+. Good quality ciss for this model cost about £35. Or you can get it prefilled with in from on of the suppliers. Have a look on our suppliers list for more info.and prices.
sensor
Post by sensor »
Hi, and thank for the quick reply,
Thats one of the ones i was looking at, along with the b40w,
I could not find your suppliers list, if you could post a link that would be good,
Thanks for the help
sensor111;35177 wrote:Hi All,
Cheers
You need to factor in the ink costs as well, whilst you can get a printer for under £150 this won't include the most expensive part which is the ink.
