Cheap Laser Printer .....
AdamB
Re: Cheap Laser Printer .....
Post by AdamB »
Hi all,
not sure on the quality of these printers but it popped up as the deal of the day on ebay - can't be bad for the price surely?
http://www.ebay.co.uk/itm/Konica-Minolt ... d=ViewItem
I guess you can't go wrong at that price. I always check how much the toners are though, had a Magicolour a while ago and came to replace the toners....ouch! As long as you bear in mind the toner costs, the price of the printer is pretty much negligible.
Good price, way below trade price (wonder why??).
High capacity cartridges (2500 yield) aren't that high yield as several lasers have 5,000 - 8,000 yield, especially on black, but prices for the lasers are much more. Each high yield cartridge will cost you more than the printer!
ASO Embroidery
Post by ASO Embroidery »
makes you wonder how they make any money on it surely must be a gimik to get you to buy ink or something
Ian M
Post by Ian M »
ASO Embroidery;33688 wrote:makes you wonder how they make any money on it surely must be a gimik to get you to buy ink or something
There are a couple of companies who give away laser printers when you buy the toner. The toner cartridges for that printer are around £35 each on Ebay.
John G
Post by John G »
The quality of older models was outstanding - still using 2 x 2300dl and 1 x 2300w minoltas, showing there age a little now but still usable. I would say at that price you can't go wrong, it's worth buying 2 just for a second set of carts :biggrin:
Cheers John
AdamB
Post by AdamB »
John G;33701 wrote:............. it's worth buying 2 just for a second set of carts :biggrin:
Cheers John
That's what I thought John, at that price :-)
My initial thoughts though were to see if it was compatible with the magic touch process ........................ alas I don't think this printer is :-(
John G
Post by John G »
I think to be used with those type of transfers it would need a straight paper path like the oki's - normally minolta's feed from the bottom and go through rollers at the top bending the page. I'm after replacing one of mine and was going to get a lexmark, as I've had print samples and they were really good for the price but this one, at that price, has me thinking again.
Cheers John
JSR
Post by JSR »
One day people will learn not to be ripped off by laser printers in the way most have learned not to be ripped off by inkjet printers. Unfortunately there is still the mindset that "it's laser, it must be cheaper to run than an inkjet".
Let's look at this "bargain" for a moment.
The Magicolor 1600W has the option of two sizes of colour toner cartridges - either 1,500 pages for £70 or 2,500 pages for £90 (black is a little cheaper, but you're buying this for the colour aren't you?). Wow, what bargain those prices are. The typical inkjet printer gives you 500 pages for £10, that's £30 for 1,500 pages or £50 for 2,500 pages - that's *half* the running cost of this laser printer. Replacing all four toners in the laser printer will cost you over £300. Replacing an inkjet cartridge for the same number of prints will cost you under £200. Look around and you'll find inkjet printers that'll do 900+ pages per cartridge (some will do much more), reducing the cost even further. We always question the high cost of running an inkjet printer, but no one questions it when a laser printer costs *more* to run than the inkjet.
Then there's the imaging unit - which costs more than the printer. It'll last for 11,250 colour pages (regardless of coverage). And then the fuser unit, which'll last longer than the imaging unit but, again, will cost more than the printer. These both increase what it already a very high cost per page even higher. Inkjet printers don't use imaging units or fuser units.
When you see how much more expensive it is to run a colour laser than it is to run a similarly-priced inkjet printer, you quickly see why the printer itself costs so little. Manufacturers have always been accused of selling inkjet printers using the "razor blade" selling technique. Now they do that for colour laser printers, but it's *even worse*.
If you're looking to buy a colour laser printer, or indeed any printer, always start from looking at toner costs, imaging units, transfer belts, and fuser units. When you've found each of these at affordable prices, only *then* look for a printer that uses them. You'll doubtless find the printer costs £500+, not £50+, but that's the price you pay for economical running costs.
And for those who say "it's worth buying just to get the toners", it isn't. Check out the reviews for this model. It's said that the printer come with starter toners which contain, at most, 500 pages worth - some say they're only 20% capacity. That's typical "inkjet thimble cartridge" capacity. You'll need to spend £200 - £300 on new toners almost as soon as you start using it. Is £55 still cheap?
There are significantly, and I mean significantly, cheaper ways to do your printing than using an entry-level colour laser printer, but if you really have your heart set on a budget colour laser printer, at least check out a place like these guys: http://www.refilltoner.com to see if the cartridges can be easily refilled on the cheap.
AdamB
Post by AdamB »
OUTSTANDING JSR - that is definatley something worth remembering.
Thank you for taking the time to add your post and info - for one, I don't think I'll bother when you see everything in prespective :-(
