Take a look at the 'suppliers' section (see the category on the main forum home page).madmargey;33613 wrote:Thanx Adam,can u suggest a good supplier, is it awkward introducing new ink to the system??
You can clean the ink out of your system but you'll need to make sure every last bit is out to avoid contamination. Then you'll need to make sure that the printer you have is a supported printer (if using supported inks).
Using supported inks gives you the profile to use the ink and also the support in case of problems.
Have a look through the suppliers (at the link mentioned above) as most of them supply packages with ink and also with ink and printer/mugs/paper etc - I won't list any as I don't want to sound too biased if I only list a few suppliers - but take a look and if you need clarification on anything post back here.
One last thing - I do hope you get sorted and if you do and feel that you'd like to support the forum then there's a donate button at the top of every page (your choice entirely).
Adam
