First Mugs - Is it me or is there a sight blue tint??
doldham
Re: First Mugs - Is it me or is there a sight blue tint??
Post by doldham »
Hi All,
Here are some images of the first mugs I've printed. Don't know if people would agree, but I think that there is a definate blue tint to the images....
I am using epson P50 and mug press bought from Coralgraph. Pressed for 180 degrees for 180 seconds (after the mug swap and heat drop stabilising)
Tried using an ICC profile (that I received from Coralgraph) with Qimage, but windows said invalid ICC profile, and qimage does not recognise it.
any advice, criticism - hopefully constructive :-) etc much appreciated.
[ATTACH=CONFIG]652[/ATTACH] Original Image
[ATTACH=CONFIG]653[/ATTACH][ATTACH=CONFIG]654[/ATTACH]
[ATTACH=CONFIG]655[/ATTACH]Original Image
[ATTACH=CONFIG]656[/ATTACH][ATTACH=CONFIG]657[/ATTACH]
[ATTACH=CONFIG]658[/ATTACH]Original
[ATTACH=CONFIG]659[/ATTACH][ATTACH=CONFIG]660[/ATTACH]
vB_ID:660
vB_ID:660
vB_ID:659
vB_ID:659
vB_ID:658
vB_ID:658
vB_ID:657
vB_ID:657
vB_ID:656
vB_ID:656
vB_ID:655
vB_ID:655
vB_ID:654
vB_ID:654
vB_ID:653
vB_ID:653
vB_ID:652
vB_ID:652
I would tigt the press slightly as it looks bit soft. it may be preasure related. please send me this icc to sales(a t)frames4photoshop.info I will have a look for you. if you have slight blue cast but colours are quite right then this may be printer related. I would download photoshop or photoshop elements trial version to try. without this you wont go to far i am affraid :(
Do you have other software you could test print from? Coraldraw, Photoshop etc?
doldham
Post by doldham »
thanks guys, will try from my wife's elements and see if it's better. Will let you know....
But pointless trying without having a profile :-(
Andrew
Post by Andrew »
What make ink is it? Didn't know Coralgraph sold subli ink.
I think it would be better for all of us to not discust 3rd patry ink suppliers on main board guys.
doldham
Post by doldham »
Thanks Paul, Yup think that I might have to call on your services. Is your offer still on for paid up member :-)
JSR
Post by JSR »
I use Qimage all the time with my own home-made ICC profiles. If I can help at all, perhaps by trying your profile with my copy of Qimage, let me know. I don't have a P50, so I can't actually print anything but I can see if Qimage will recognise the profile or something if it would help.
