FAO SarahJayne, ref magnetic sheets
AdamB
Re: FAO SarahJayne, ref magnetic sheets
Post by AdamB »
SarahJayne, you asked in a post regarding magnetic sheets that was deleted as the forum software was updated last night. It's no problem though as I remember what you asked regarding magnetic sheets for sublimation or inkjet.
A search of the forum finds the following posts regarding magnetic sheets: http://www.dyesubforum.co.uk/vbforum/se ... hid=122016
I remember a few weeks ago finding printable magnetic paper (well card, as it was very thick) in Asdas or Tescos (or both) - might be the best place to start as sometimes you'll be lucky enough to find an offer.
Also, you can get inkjet printable magnetic paper from various sources, but if you want to keep your eggs in one basket and order from the same sources as sublimatable blanks then the links *below may help:
Transfer Press (inkjet): http://www.thetransferpress.co.uk/cgi-b ... 75MPP11005
BMS (sublimation): http://www.printerowners.co.uk/sublimat ... -sheet.htm
BMS (not printable but good for vinyl) http://www.printerowners.co.uk/hardware ... -sheet.htm
Google Search: http://www.google.co.uk/search?q=A4+ink ... 80&bih=596
*note, I'm sure that many suppliers also provide magnetic paper - if someone else knows of a supplier that provides the item then please let us all know. I didn't have time to look through every supplier as I have a bacon buttie going cold! (lol)
sarahjayne
Post by sarahjayne »
only just seen this - thanks a million.... Now I want a bacon butty ...
pitkin2020
Post by pitkin2020 »
MDP supplies for mags (for vinyl) £5.95 per metre (x 24inch/610mm)
Glen Print
Post by Glen Print »
Hiya SarahJayne. I have an MDP store quite close who stock mag roll.
If you would like to give me the measurements of the required signs,
I will order it in, print it on my wide format and courier it to you.
Cheers, Martin
