looking for new mug press
Re: looking for new mug press
I have been looking at mugs press as I need to get back up in soon as my Geo Knight will be needing some work done on it, can anybody recommend one
nothing wrong with them Jenny:
they great little machines. perfect for backup and under £100
where did you get the mug press from. I should have done brought another mug press ages ago just in case, and I'm in the middle of a order and the geo knight started to play up
you can get one from coralgraph with two attachments for £119 delivered and 12mc warranty http://www.coralgraph.com/heat-press/di ... andard-mug
or you can get DF1 from BMS. but i think there is only one attachment. i am not sure you need to chek this one.
Is there difference, because of the price. I didn't understand about the idling, time, can you not take one mug out and put another in straight away, sorry if I sound stupid but when I have a large order I need to keeping going
i dont know nothing about idling. when I used one I printed one mug after the other with 25min brake after each hour.
I've got that one and seems pretty good (not had any others mind) came with some extra attachments/wraps. Seems to give a nice even print across the whole mug on a full wrap one.
One after the other works for me.
Downsides that I've noticed, the led readout is a bit dim, but might be as it's got a window behind, might even be adjustable. Socket for attachments is a bit akward due to position, but at least it doesn't come out when you don't want.
Upside is that if I want to check a temp the Scott at BMS knows all the answers.
dJ
dJ
I went on coragraph web site but it looks like they only take pay pal, I could not see a telephone number to see if they took card
