Mug already pressed
Re: Mug already pressed
harlequeen;30819 wrote:Basically, I was doing a mug for a friend then after I did it she asked could I put her name on it! I might try it just to see.
Let us know what happens then !:biggrin:
harlequeen
Post by harlequeen »
No, I wasn't really thinking of preparing mugs and adding to them later, I just wondered about adding a name after the initial printing had been done. I'm going to print another mug for my friend with her name on. I'm so green at this that I need to ask a lot of questions. :)
Thought that must have been the case :-) Just print another mug, everyone's happy!
djhutton
Post by djhutton »
I have a few duff mugs here (white spots, unside down etc) that I have been using as scrap to check colours etc and on some there are more than two bits of artwork, some over others. None seem to have been affected by subsequent pressings.
DJ
Lee
Post by Lee »
If you're going to print another mug anyway, why not try reprinting the first one - that way at least you will know and if it does spoil you can go ahead and print the back-up mug...
