aluminium printing
smitch6
Re: aluminium printing
Post by smitch6 »
Hi
following on from my dash :)
i've been thinking about making it out of ally
what is the finish like with subbing onto ally?
i have never tried it or seen the finish
thanks
xpres aluminium in white is nice and glossy. i love it. but only white, if silver i preffer brushed effect.
smitch6
Post by smitch6 »
does it scratch ?
i dont scratch mine :) but it looks very solid. I have some pictures printed and from time to time I wipe it with some pledge to get rid of the dust. looks like new. no damge or nothing.
smitch6
Post by smitch6 »
okies kool
is this the same stuff do you know?
as xpress the sizes are too small for what i want
500mm x 400mm roughly
http://www.ebay.co.uk/itm/WHITE-3mm-ALU ... 1763wt_907
John G
Post by John G »
Could you not make it out of ally composite panel and then get it engraved?
smitch6
Post by smitch6 »
haven't got the money :~
we've run out a few weeks ago so have to do things as cheap as poss now
djhutton
Post by djhutton »
Have a word with BMS as they can cut you metal to suit the size, several finishes IIRC and seems to print nicely.
DJ
Andrew
Post by Andrew »
Subli aluminium will scratch if used as a dash. I do like the brushed silver finish but all depends what you need to match it to.
I doubt you will get that size (even from BMS) as the standard sheets are 600 x 300 or thereabouts.
John G
Post by John G »
Would sub metal be uv stable - I was thinking if on a boat it would be open to the elements and fade quite quickly.
