icc for s21
Jo1507
Re: icc for s21
Post by Jo1507 »
Hi,
Wondered if anyone could help with an icc for an epson S21? We are using Artainium ink and Tru-Pix paper. Any help would be much appreciated.
[h=2][/h]Jo
swimwivsquid
Re: icc for s21
Post by swimwivsquid »
I don't think that there is a generic one for the S21 but try one for one of the supported printers as I used a D88 profile for a Stylus cx3200 and it worked fine. Its worth a try as the heads are similar if not the same in a lot of the epson range.
Has thanked: 13 times
Been thanked: 12 times
Re: icc for s21
I've used the D88 profile with an S21 before with acceptable results.
mrs maggot
Re: icc for s21
Post by mrs maggot »
Re: icc for s21
mrs maggot;28839 wrote:http://www.erange.co.uk/colour-manageme ... rrency=GBP not a bad price
but this is not suitable for calibrating printers Laura. only screens. good for photographers tho...
JSR
Re: icc for s21
Post by JSR »
Paul's right. You want either the "ColorMunki Photo" or "ColorMunki Design", not the "ColorMunki Display". You can expect to pay around £300 - which sounds a lot but before the ColorMunki you could expect to pay at least 2-3 times that just to do the same thing.
Best investment I ever made (with much thanks to Paul for pointing the way!). My next investment is to get a decent monitor that I can calibrate better.
mrs maggot
Re: icc for s21
ah, thanks paul, better to remove my post then to save confusion
JSR
Re: icc for s21
Post by JSR »
mrs maggot;28878 wrote:ah, thanks paul, better to remove my post then to save confusion
I'd say leave the post there - so that others know the differences between the ColorMunki models. Wouldn't want someone buying the cheaper one and wondering why they can't profile their printer.
