Why I hate Windows.....and why I have to use it!
Any OS, software in here.
JSR
Re: Why I hate Windows.....and why I have to use it!
Post by JSR »
Matt Quinn;26552 wrote:It's always been the way with both OSs and a lot of software - As I seem to recall remarking earlier, there really isn't very much of note I'm doing today with PCs that I wasn't doing a dozen or more years ago. Microsoft always was prone to P-ing the power of the supporting machine up against the wall. And it's one big con - It's actually very rare for developments to be really new; or particularly useful... Certainly very rare for 'new' features to appear that would truly be totally unachievable with properly coded software on the machines of 8 or even 10 years ago...
I remember thinking similar things when Windows XP first came along and I had to ask myself what I could do with XP that I wasn't doing with 98SE. Microsoft constantly tout the new OS as being "faster" - but then the specs demand a much faster system. The original OS would go much faster on a faster system! Barmy. I have a nice small laptop here from years back that'll run Windows 98SE quite dandy - with its 16MB RAM and 1GB hard drive. Yet we have to throw perfectly working machines out because of software and hardware requirements.
A couple of years back, I tried to start moving over to Linux. Not the 10MB one (that's a little too restricted for anything but the basic stuff, or if you really want to roll your sleeves up) but to a 100MB one that boots from my SD card or USB stick. The biggest stumbling block was lack of hardware support - particularly printers. Something as simple as printing was like a hurdle of epic proportions. That's something that hasn't changed since I first tried out Linux some ten years ago.
I may moan about Windows and Microsoft until I'm blue in the face, but Windows does "just work" with everything I have. But that seems not to be guaranteed these days either. If you go to a 64-bit version of Windows, I understand that most software and hardware needs to be chucked in the skip. And it's not always certain that what you run on Windows XP today will even run on a 32-bit version of Windows 7 tomorrow. They don't make it easy to upgrade.
Has thanked: 13 times
Been thanked: 12 times
I ran the Upgrade checker which does a good job of testing all hardware and also states which software will/won't run. Everything I had installed runs ok under 64 bit.
mgibbs
Post by mgibbs »
JSR;26557 wrote: If you go to a 64-bit version of Windows, I understand that most software and hardware needs to be chucked in the skip. And it's not always certain that what you run on Windows XP today will even run on a 32-bit version of Windows 7 tomorrow. They don't make it easy to upgrade.
64Bit XP was certainly a nightmare for compatibilty (or lack thereof). 64bit Windows 7 has far fewer problems. So far we've not found any program that works on 32 bit Win7 that doesn't run on 64 bit.
If you have the pro version of 7 you have xp compatibility mode which essentially runs a copy of xp in a virtual machine if you have any essentail XP programs that don't work under 7.
Mark
Draner
Post by Draner »
if you ask adobe very nicely, your photoshop licence allows you to use it on 2 computers (only one at one time though) they may give u a new product key for Mac
Andy no longer @ BMS
JSR
Post by JSR »
mgibbs;26563 wrote:If you have the pro version of 7 you have xp compatibility mode which essentially runs a copy of xp in a virtual machine if you have any essentail XP programs that don't work under 7.
I already have Windows 98SE running on a Virtual Machine for software that won't run right on Windows XP! :biggrin: And I didn't have to buy the "professional" version of XP for this to work.
I guess the "pro" version of 7 costs much more than the non-pro version?
Not that I'm considering 7. It's too bloated to run on my netbooks, so it's a no-go for me no matter what the perceived advantages are.
Draner
Post by Draner »
Ask not what Windows can do for you, Ask what you can buy for Windows.
mgibbs
Post by mgibbs »
JSR;26566 wrote:I already have Windows 98SE running on a Virtual Machine for software that won't run right on Windows XP! :biggrin: And I didn't have to buy the "professional" version of XP for this to work.
Pro does cost more than the Home versions yes. The main difference is that Pro supports domains on the network.
Mark
I am running Win 7 and it works at treat. Have Coreldraw X3 and Adobe CS5 Master Edition installed and never get any problems (although I doubt if I am doing the sort of photo editing that some of you are doing). In fact its quite the opposite. I used to run XP and my version of CorelWings (embroidery creation software) would not run. On Win 7 it does.
draig
Post by draig »
I used to love OS2 Warp, not bloated and ran like a dream. Then MS did the dirty and marketed windoze, not wanting to put a lot on a forum but there is a huge history behind this.
First OS i ever used was CP/M then Xenix ah those were the days.
Sharon
